Update libstagefright.so on MK808B, Finless 1.7c
    Hi everyone,
    I'm running an MK808B with Finless 1.7c. I don't want to upgrade to finless 2.0 because of all the instabilities I hear about with 4.2.2. My 4.1.x-based finless 1.7c is rock stable. I do however want to upgrade the libstagefright binary because there have apparently been fixes made by rockchip. Does anyone happen to have a newer libstagefright binary for the MK808B kicking around that they can upload for me? Thanks!
    Originally posted by evilmonkey1987 View Post
    Hi everyone,
    Use this rom instead - http://www.freaktab.com/showthread.p...30%29-_Sep2013
    Much faster than Finless, based on 4.1.1 Android and includes the new libstagefright.so file.
      Or if you want to stay at finless rom, here is a new libstagefright.so:
        Thanks everyone!! Phinc, that libstagefright patch worked wonders, thank you. I tried updating to the newer ROM, but it seems to have trouble going from Finless to that one. I think I would have to reinstall stock, then try to go to the minix port. I won't do that for now, finless works fine for me.
          How can I update libstagefright.so on Finless 1.7? Is it OK just to replace file? And where is it located exactly?
            In system/lib
            You can use the libstagefright I posted in my Update Pack as it's the newest one, works with Android 4.2.
              In system/lib
              Also works with Android 4.1.x?
                For Android 4.1, the digitop Nov and XBMC Edition rom already has the latest libstagefright.so for Android 4.1.
                Try installing one of those roms if you aren't on one of them already.
                  Although Antutu is higher on the Minix firmwares, Finless 1.7 will benchmark Epic Citadel higher, and will also play the background music which is broken in all Minix firmwares. I personally think Finless 1.7 is the fastest 4.1 rom you can get.
                  If you can deal with patching a few things like the libstagefright, getting rid of the boot animation (sorry Finless, but it's an aquired taste) there is no real need to ever change roms unless something is broken on 1.7, like ethernet on boot. It's also given me the best data transfer of all roms at the cost of signal strength.
                  If we could get rkremote v2 on that rom I would switch in a heartbeat.
                  Currently Using:
                  2 x Nvidia Shield TV | MiniMX III
                  Retired Devices:
                  MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
                    Re: Update libstagefright.so on MK808B, Finless 1.7c
                    http://www.multiupload.nl/W6XSLHRDOI
                    Download links are no longer working, can someone share a link please?
                    Sent from my HTCONE using Xparent Skyblue Tapatalk 2
                      You can download the cwm installable libstagefright from my rom...it should work.
                        The fileswap link works. Or try prahjister's one, it is propably newer. If everything fails let me know, then i will upload it again.
                          putloker(now firedrie) works
                            Originally posted by badskills View Post
                            I thought there were more files to it. Thank you for sharing a link.
