About installing armbian on s805 TV box ,written into emmc
I now have an image file that I can use
Armbian_5.67_Aml-s805_Debian_stretch_dev_3.10.33_20181124.img
But it is not have the install.sh file, written into emmc.
other versions of kernels cannot start my device.
Excuse me, you are there other image files whose kernel is 3.10.33 and can be written into emmc.
My dtd uses meson8b_m201C_512M.dtb
my English is not good. Thank you
Do you need it installed to eMMC, or is it okay if it remains on the SD card but automatically boots from there? Because if you just want it to boot Armbian automatically, you can use the `armbian-config` and select System > Install > Install/update the bootloader on SD/eMMC.
I'm just asking because I wanted to do the same as you (using `nand-sata-install`, but alas it seems to not exist yet in this version of Armbian), and using this method the device will boot directly into Armbian without having to use the toothpick boot method.
