Stock firmware for TX3 mini 2021 Board 1.6 S905W CPU 2GB/16GB
    Hi everyone, I share the stock firmware Android 9 for the new TX3 mini of 2020-2021 (called version 2021), the one with the following datasheet:
    • CPU Amlogic S905W
    • 2 GB RAM / 16 GB eMMC
    • Board CS_905W_TX_2C_N_MK_V1.6
    • WIFI chip: SP6330-X (I think is AP6330)
    Photos of TV Box:
    Photo 1
    Photo 2
    Photo 3
    Photo 4
    Photo 5
    There are 2 variants for this TX3 mini 2021 version:
    • Variant 1. Is a version using Dual AP6330 wifi chip, can connect 2.4 and 5G bands with Bluetooth connection (the one I have).
    • Variant 2. Is a version using a single 9012 wifi chip that can only connect to the 2.4G band.
    Stock firmwares for Variant 1 of TX3 Mini 2021:
    • Android 9:
      • Stock Android 9 firmware (date 2020-09-29): DOWNLOAD (RECOMMENDED. Kernel 4.9, All working.)
      • Stock Android 9 firmware (date 2020-11-17): DOWNLOAD (Kernel 3.14 and WIFI 5GHZ doesn't work)
    • Android 7:
      • Stock Android 7 firmware (date 2020-11-06): DOWNLOAD (Kernel 3.14 and WIFI 5GHZ doesn't work)
    Stock firmwares for Variant 2 of TX3 Mini 2021:
    • Still not available. Will update if I get it
    Sources (you can translate from vietnamese):
    Source 1
    Source 2
    Hola Amigo!! Excelente tu aporte, me solucionaste la vida con mi equipo con el Android 9.
    Pero si me interesaría probar lo que mencionas como Firmware de stock para la variante 2 de la tx3 mini.
    Aguardo puedas actualizarla!!
    Saludos!!
      Amigo, descubri que con la actualizacion del Android 9 (Recomendado) el firmware es para 1 GB de RAM, ósea, lo instale y automáticamente lo dejo en 1 GB de RAM a mi tv box que relamente venia con 2 GB de RAM.
      Sabes por que seria ese inconveniente?
      Saludos.
