Amlogic S905X3 vs S905X4 – Features Comparisons
    Amlogic S905X3 vs S905X4 – Features Comparisons via CNXSOFT
    AV1 capable Amlogic S905X4 processor has been expected for more than a year, and only now are we starting to see announcements of S905X4 TV boxes and development kits.
    So it may be a good time to compare the features of the new Amlogic S905X4 processor again its predecessor, namely S905X3, and see if there are other notable differences apart from support for AV1 open video codec.
    We’ll use data from S905X3 specifications, S905X2 vs S905X3 comparison, and a post on SDMC LinkedIn page.
    CPU Quad-core Cortex-A55 up to 1.91 GHz Quad-core Cortex-A55 up to 2.0 GHz
    GPU Arm Mali-G31MP2 with support for OpenGL ES 3.2, Vulkan 1.0/1.1, and OpenCL 2.0
    Neural network accelerator Optional 1.2TOPS NPU N/A
    Memory DDR3-2133, DDR3L-2133, DDR4-3200, LPDDR3-2133, LPDDR4-3200 SDRAM up to 4GB
    Storage I/F eMMC 5.0, NAND Flash, SPI NOR/NAND, SD
    Video Output HDMI 2.1 up to 4Kp60, HDCP2.2, CVBS HDMI 2.1 up to 4Kp60, HDCP2.3, CVBS
    HDR HLG/HDR10/ 10+ Dolby vision, TCH PRIME
    Audio Stereo DACs, S/PDIF In and Out, 8-ch PDM, 12-ch PDM in, 12-ch PDM out
    Video Decoding 10-bit H.265, VP9, AVS2 up to 4Kp75, H.264 4Kp30 AV1 up to 4Kp120, 10-bit H.265, VP9, AVS2 up to 4Kp75, H.264 4Kp30
    Video Encoding 1080p60 H.265/H.264
    Voice & Audio Processing VAD, ASRC/EQ/DRC VAD, ASRC/EQ/DRC, 2x HiFi4 audio DSP
    DRM & CAS Widevine, PlayReady, VMX, Irdeto MSR 3.2 Widevine, PlayReady, VMX, Irdeto MSR 3.2, Nagra NOCS3.2
    Ethernet Gigabit Ethernet MAC, and 10/100M PHY
    USB and PCIe 1x USB 2.0, 1x USB3.0 or PCI-E v2+USB 2.0 (multiplexed)
    Crypto Engine AES, TDES, SHA-1/SHA-2/HMAC, SM4 AES, TDES, SHA-1/SHA-2/HMAC, RCA
    DVB 2x Transport Stream (TS) inputs, ISO7816 smart card standard
    Process 12nm
    Amlogic S905X4 will be slightly faster due to the higher (default) maximum CPU frequency of 2.0 GHz, but most people will not notice the difference. S905X4 is supposed to support Vulkan 1.1, while S905X3 does not, but I believe this is just due to more up-to-date Android SDK, and not differences in the silicon itself. S905X4 supports Nagra DRM, a more recent version of HDCP, and integrates a dual-core audio DSP which may be why there’s no optional AI accelerator. There are also some minor differences with the crypto engine.
    So from a user perspective, the only real difference will be support for 4K AV1 hardware video decoding that boosts efficiency by 20% compared to H.265/HEVC, and saves 30% bandwidth compared to H.265/VP9. Since AV1 is supported by Netflix, Amazon Prime Video, YouTube, and other online video streaming services, you may experience less buffering for the same video quality, or higher video quality for an equivalent bitrate.
    Jean-Luc Aufranc (CNXSoft)
    For more amlogic s905x4 android tv box, H96 max x4 can be recommended
      Isn't that tvbox fake?
      A few weeks ago we knew the release of the new TV-Box H96 MAX X4 with circular design and its alleged configuration with the new SoC Amlogic S905X4 and
        WOW this is really interesting, I thought there was going to be a new amlogic S905x4..
          From now on time to go 905X4
          905X3 is over!
          I'v already tested 905X4 by Mecool KM6 Deluxe and more faster&stable!
          and sure with some of BUGs too and one OTA arrived!
          Welcome other 905X4 Boxes
            Are Both socs compatible? Possible to Flash S905x4 fw on s905x3 device?
              905X3 is over!
              Always depends on firmware!
