Firmware for RK3229 with SCI S9082C
Hi, I am looking for a firmware for box with RK3229 (or 3228A) that supports SCI S9082C Wi-Fi chip. I searched for it myself but with no luck. I tried using driver kernel module (9082xs.ko) from Amlogic box but it was for kernel 3.14 and RockChip boxes are using 3.10 kernel. If that matters this box has 1GB of RAM and 8GB ROM eMMC. Thanks in advance!Tags: None
Okay
My Bad
Did u read the whole thread at XDA
There is reference to your situation
So if driver for wifi chipset is in 3.14 kernel
The original Factory Firmware must have Driver for wifi chipset S9082C in Kernel 3.10 ?????
Rockchip has ported Kernel 3.14
Of course u cant find Factory Firmware.(Nothing at C gadgets review?)
What is status of Box currently?
Bricked/soft bricked?
Maybe test LibreElec for this Box
There are Roms to test that Match CPU and DTB
You will have remote control
But no wifi
Maybe USB wifi adapter
Or just use Ethernet if available
Originally posted by freddy View PostSo if driver for wifi chipset is in 3.14 kernel
I see
Hmmmmmmmmmm
I always thought was built in Kernel/interface with Device tree blob/loads at startup/bootload
Module loads in system when called for Wifi/turn on wifi
Ive been wrong many times before
Lol
I do not think there is AlexElec for Rockchip 3229 or any Rockchip
Again the wrong thing many times....
You may have more success with Device tree Blob in LibreElec
Either way you are up n Running/Flawless/except wifi
When you got the Box The Original Factory Firmware had been removed/replaced with other Rom/Android 6.0
Good Luck
Happy Testing
There are currently 1793 users online. 1 members and 1792 guests.
