Station P1 RK3399 AndroidTV 10 ROM
    Station P1 AndroidTV 10 Firmware
    Changelog v1.0
    • Add AndroidTV bootanimation
    • Fix ATV Play Store
    • Fix Youtube VP9 freezes
    • Add Ad-blocker(blocks > 300000 sites)
    • Add Kodi, Nova VideoPlayer, SmartTube Next, MiXplorer apps
    • Grant storage permission for installed apps
    • Changed default keyboard to LeanKeyKeyboard
    • Lots of UI optimizations to increase speed(30-50% in several places)
    • Changed DPI to 320 and frame-buffer to 1080p
    • Enable support for VirtualXposed
    • Add Power menu app(Need root)
    • Use App-Drawer app to access normal Android apps(non Leankback ones)
    • Add several remote control keylayout files
    • Add 10-bit H264 video playback support
    • Add Double press Home button for Recent apps
    • Add Fake Wifi Support for ethernet
    • Remove stock root
    • Add Magisk Root support
    • Fix Exfat Filesystem support for USB drives
    • Add support for Nintendo Switch controllers
    • Build as Release-keys instead of Debug-keys, might have better compatibility for some apps
    • Add auto frame-rate switching
    • DuckDuckGo browser for increased privacy and tracker blocking
    • Netflix ATV app preinstalled.
    • RadioDroid radio station app built from latest source code
    • Add mouse browse support for browsers
    • Add Sleep menu to Power Off Menu
    • Aerial Dream screensaver app built from latest source code
      (Lots of code changes done to support AndroidTV 10)
    Download link v1.0:
    https://mega.nz/file/RvZ21JwY#j2q0Z2...h2_toQx3vAuR2I
    Flash with AndroidTool v2.69/v2.71
    Buy me a beer?
    You are an efficient developer,Thank you for your help.
      Changelog v1.0
      • Remove stock root
      Download link v1.0:
      Buy me a beer?
      I bought you a beer?thanks.
        perfect ROM.
          i cann‘t wake up the device with the power key after shutdown?can you fix it?
            I'll check for you.
            If you long press the power button and choose Sleep, then short press the power button again to wake up,
            can that work for you or is the behaviour different?
              I'll check for you.
              choose sleep?then short prees the power button can't wake up the device.
                Hi, you can post a topic here and our engineer will reply you ASAP.
                https://www.stationpc.com/forum.php?...display&fid=46
                Thank you.
                  Hi, thanks for the great job ?
                  Will this work on Yundoo Y8? I don't even need wifi if that doesn't work.
                  • mo123
                    mo123 commented
                    Editing a comment
                    Most likely won't work on that device.
                  Hi
                  I tested with updated firmware made, added more kernel drivers from stock kernel.
                  Short press power goes to standby, press power again wakes up.
                  Long press power and choosing sleep, same as above.
                  Long press power and choosing power off, completely powers off.
                  I will upload tomorrow then you can test again.
                  Do you use stock remote with orange/red dpad remote with round edges?
                  Sent from my A9 Pro using Tapatalk
                    Hi
                    thank you.
                      thank you.
                      Hi
                      New v1.1 firmware released.
                      I posted on the Stationpc site.
                      Here is also a guide to use the new script feature for Kodi, Nova Video players and to use other launchers on AndroidTV with widget support.
                        Will the ROC-RK3399-MEZZ-M2-POE expansion card work with Android installed?
                          Changelog v1.2
                          Fixed landscape orientation for apps like APKPure, TikTok Lite
                          Updated adblock
                          Preinstall support for 64-bit apps instead of 32-bit apps.
                          Some apps will now run faster
                          Updated apps
                          Updated permissions for apps
                          Fix external storage devices prompting to format every time they are turned on if they contain bad sectors
                          Disable Double-click the Power button to open the Camera app
                          Add Nebula to show non AndroidTV apps on the AndroidTV Homescreen, no need to buy Sideload Channel Launcher.
                          Download link v1.2:
                            dts-hd ???????dts???
