Netflix 6.13 for Android TV Certification Patcher for L1 devices
    Hare is a quick and dirty patcher for Netflix 6.1.3 that allows 1080p HDR ( 4K on some devices as well) - it is the android TV version of the app and has homescreen channel icons
    The patch is device model/specific and it requires you get your current Netflix ESN and slightly modify it ( instructions are given when you run the batch file)
    DOWNLOAD: https://t.me/NetflixAndroidTV/23
    For Pre-Patched APKS and support go to https://t.me/NetflixAndroidTV
    Instructions
    download and extract the zip somewhere
    Run Start Patcher.bat
    Follow the prompts
    install the resulting APK on to your device ( remove any existing non patched versions first)
    watch Netflix on your "uncertified" device perfectly fine
    Requirements:
    YOUR ANDROIDBOX MUST HAVE WIDEVINE L1
    Win 10 ( maybe 7 too)
    Java JRE
    (based on code from Dealaxer's tutorial - https://forum.xda-developers.com/t/a...etflix.4232373 )
    Click image for larger version  Name:	photo_2021-02-15_17-42-27.jpg Views:	0 Size:	0 ID:	820512
    Unzip - Run - follow the prompts - enjoy ( install latest java JRE if you for some reason dont already have it and get errors) - may need windows 10
    Enviado de meu RMX1931 usando o Tapatalk
      Kaspersky warns me of trojan. Is the download safe?
