Mecool KD1 Stick with Android TV OS
    This is one of Mecool's newer Android devices, and is Google Certified. It is using the Amlogic S905Y2. Here is my review of this stick.
    Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
    Can I burn mecool kd1 rom on X96s stick? this is the same cpu and gpu do you think it will be possible or this will be brake the device? I have 32gb verison. and if the wide level 1 will be on X96s if I succeed to install ?
      I don't have a ROM for this device, yet........... Mecool has not provided one.
        I see thank you. I think this device not worth anything without widene L1
          It has Google Widevine level 1, just not Netflix certified........ So, it supports most other streaming app, just not Netflix.......
            I know that the kd1 yes. I mean the x96s that I have not worth anything
              If you want streaming services, then yes, you are correct..........
                Level 1 is good.
                Wonder if flashed 3rd party ROM,will it be erased?
                What's the relationship between Wodevine level with ROM? Box Mac address registered with Google?
                Can we copy or move or spoof this kind of widevine security?
                Can ROM developers copy netflix certiified device's ESN like Xiaomi stick to other boxes?
                  On the Mecool KD1, HDR remains activated at all times, even on SDR content.
                  Did you notice that?
                  There is an option to switch HDR to SDR and SDR to HDR but it doesn't work? A bug on my KD1 or is it the same on yours?
                    My TV that I purchased a few months ago, supports HDR, so this bug does NOT affect me. However, if it I still had my older TV, then the KD1 would be useless for me, same as the Tivo stream 4k stick, it suffers from the same bug.
                    The Mecool KM6 Deluxe had the same bug, but they corrected it with a firmware change.
                      Ok thank you, that's what it seemed to me
                        ...same as the Tivo stream 4k stick, it suffers from the same bug.
                        FYI - TiVo Stream4K corrected the HDR bug fully in the last update in June, works perfectly now for switching from SDR to HDR10/DolbyVision and then back to SDR automatically.
                          Thanks for that info.........
