I'm trying to help the Original Poster.
cs-918 after update with levy firmware LAN connection not work
Originally posted by imet View PostI'm trying to help the Original Poster.
BUT now I've disassembled my device a second time (some minutes ago) and you are right there IS a RTL8201F (I don't know with chip is on the V2.0)...
Is the sock your own dump, or from where did you get it?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by borislivs View PostT-r42 is k-r42 with BT
T-R42 / CS918BT => PCB: B351_V1.0 => WLAN: AP6210 + LAN: asix ax88772
K-R42 / CS918 => PCB:CH001 TN-BX09_V2.1 = > WLAN: RTL8188 + LAN: RTL8201FRK3288 Devices
I found another CS918 Firmware
I think it is stock 20130701, but Chinese version???
Seems so that it is also called EKB311
(without BT 2013-08-29 ... the newer is with BT)RK3288 Devices
all other am try and not working
Originally posted by apolon View Postam try this firmware and have connection but very slow internet
still not working well
But first time you have a connection
1. Do you use Ethernet?
2. Do you have disabled WLAN?
BTW: in witch way do you get your Box-IP? DHCP? I'm asking because the mod versions at the board have problems with the Ethernet MAC-Address...
(I always prefer to give my devices manually IP addresses...)RK3288 Devices
Originally posted by imet View PostI use the stock rom of T-R42 from geekbuying.com.RK3288 Devices
There are currently 5228 users online. 3 members and 5225 guests.
