H96 MAX Rk3566 4/32GB or 8/64GB Dual Wifi BT4.0 USB3.0 Gig Lan Google Voice Youtube Rockchip Android 11 Smart TV Box
    Originally posted by djdram View Post
    Real 4k(UHD)60fps [3840x2160 / 60p] on h96max rk3566?
    show resolution settings (Settings - Screen - Resolution) and firmware version
    hmmm .. did you read your answer before posting?
    I posted a picture of the TV playing on 1080p60p hdr mode , and another one , at 4k60p HDR ... explain how do you “set” a different TV mode than the device RESOLUTION
    no need to show any setting , screen , resolution ... it’s already shown on the TV you play the video ...
    this is what I did , downloaded from YouTube webm 4k60HDR videos. (webm , not mp4) ... and opened these files with “media center” or legacy video player .... only these apps use rk3566 hardware for decoding And playing in HDR mode ... any other player (software , YouTube , vlc , kodi ) are not using hardware decoding or HDR mode switch
    I am using HK1 RBOX R2 (rk3566). ... all these different brands come from the same factory , they just change the label
        Duh .. and once you do that your TV changes mode and shows you the current mode like in my screenshots , that’s why it’s not showing the “HDR” word on the shot where no video is playing
          H96MAX not 3840x2160p60.00 (Ultra-HD) and 4096x2160p60.00 (4K) resolution
          60FPS?! (UHD60P - 4K60P)
            max resolution H96MAX
            3840x2160p30.00 (Ultra-HD) - UHD30P
            4096x2160p30.00 (4K) - 4K30P
            30FPS!
              Last edited by djdram; 20 August 2021, 12:42. Reason: Not 3840x2160p60.00 (Ultra-HD) and 4096x2160p60.00 (4K)
                Which part of the tv resolution shown on my pictures is not clear? Once you set there , your TV changes resolution as well ...
                I think I understand your question ...
                the firmware I am using on my box , HK1 RBOX R2 , have 4Kp50 and 4kp60 under settings as well
                and currently don’t have a 4K display here , to take a picture , I did the hdr test on my parents house .. connected to a 2021 Samsung 4K tv
                at this moment it’s connected to a 1080p monitor , so no 4K options shown under resolution settings
                  for example setting from another device
                    you're in luck, h96max doesn't have them
                      If I’m not mistaken , it’s just a few lines on a xml configuration file inside the device ....
                        edit /system/usr/share/resolution_white.xml not working, bug in kernel
                          New Firmware H96MAX 10.08.2021
                            Such a shame they don’t appear on OTA ...
                              updated now only 1080P maximum))))))
                              in the next update, the box will become 720P)
                                hmm..
                                Its a full firmware IMG file... not a update zip
                                So, im not going to install it..as I will lose all my apps and tweaks
                                cheers
