On the blog there's mention about a new stock firmware for 808B, do anyone have it yet?
aaronm32 says: October 24, 2013 at 2:53 am I just bought an mk808b from GeekBuying and it came with 406j205_09_2013 firmware. Is there a place I can download this version as a backup? Before I start installing apps and messing with it, I want to make sure I can re-image it back to factory settings. Thanks!!!
I don't think the rom will have any better performance than one of the custom roms.
Also MiniX said they will release new firmware in November. Since those roms are compatible with MK808/B they will work much better.
