QX II testing report
    I got 2 engineering sample for testing. Here is the testing result for share. The earlier version used internal antenna. Signal receiving ability is weak. The newest version using an external antenna, signal strengthened. QX II come with aluminum back cover, improve the heat dissipation capacity. Front cover is a piece of acrylic film. You can view the circuit board inside.
    Here is the specification
    Device information:
    IMito_RK3188_1080P_V422_131024 support true 1080P output. I converted 2 blue ray movies (Avatar and Man of steel) for testing. The result is excellent. The frame rate of these two movies only 23, I will increase the frame rat to test it later. Here are some screen capture of the movies.
    The movie properties:
    This stuff supports 720P USB cam. According to the technical manual, android supports automatically recognize uvc and rk29camera drivers. It only support yuv422 data format USB camera. Mjpeg data format is not supported. I have tested Logitech C310. It works very well. Due to the build in camera app always stopped. I have to install third party camera apps to test the photo taking function. I checked the internet, seems many devices have this issue after upgraded to 4.2.2.
    Video conference
    I tested few IM (QQ, skype, oovoo). The video quality is very good. For Skype, If no camera detected, the apps would dropped the connection. You need to plug the usb cam on the USB port directly, if not the camera would not be detected sometimes.
    Picuntu
    I can download picuntu to QX II. Bluetooth no works, mali400 GPU no works. I can connect to the internet by the build-in wifi. I tried to upgrade it to 13.10, but the GUI can't be loaded any more after upgraded. Other function still works. I will try it more and post the result later.
    any comment or questions or you want to know any other testing result, please reply this thread or send mail to me.
    ([email protected])
    Good review!!, any news about the stock firmware? what wifi-BT chip are they using? how about wifi strength and stability?
    leolas.
    My devices:
    Gearbest.com)
      leolas.
      It using AP6210 chipset. The newest version changed to use external antenna. The signal receiving is very good. The device five away from the router 5-6 meters and a 3“ brick wall between them, but the signal still very strength. WiFi connection is stable. In previous version, the bluetooth has a little bit unstable. It would disconnect and reconnect frequently. this issue seems has been fixed in the new firmware. But the USB cam still make me confuse. It can't be started sometimes, need to do unplug and replug.
        some pictures of skype app:
          Download stock rom?
          Very good review Nicholaswc.
          Where can we download the stock rom IMito_RK3188_1080P_V422_131024
          I have the stock rom iMito_RK3188_V422_130927 in the QX2, and I can't find the new rom.
          The wifi and the bluetooth are not very stable in this old version.
            It is under testing still. The USB cam and some functions need to be fine tune. I hope it can be launched within 1-2weeks with the new hardware. I will get the manufacture 's approval to put the final version firmware for your download then.
              Is your stock rom true 1080p version?
              In my memory, I have tested few version, Only one has bt unstable issue. But the wifi works well.
              Is the camera function well with the stock rom?
                No, this version is 720p scaling to 1080p
                Sorry, but i no have an usb camera to try it
