thanks
X96 MAX 4GB 64GB Problem
Originally posted by dacecar View PostI have same problem. can't update the installed apks. I can't install any apk from google play
try to wipe all the Google Apps , Store & Services , reboot and try again , of course the Internet must be ON ,
any other Stores installed like Aptoide ??? u can use a Cache & Dalvik Cleaner , maybe it helps ,
good luck / gefattern
There are currently 2065 users online. 6 members and 2059 guests.
