Help me to unbrick S922X Beelink GT-King Pro
    The box was flashed with firmware from wrong revision. As a result, we have a brick. There is no image on the screen, it is not boot from SD-card, not detected by UBT. Can anyone help me find the pins that need to be closed in order to unbrick the box?
      My devise stucked at booting after plugging a wrong(higher) power adapter to it. am thinking my problem maybe a walkover who can help please.
        You could try Burn Card Maker.
          It doesn't help in any way, the box refuses to boot from the SD card
            leshiy2k any solution to find the pins? I was installing an update when my mother unplugged the device.
            It got installed but now I cannot make new updates because it's not "seen" by pc.
              Hi ,
              unplug while flashing , but full installed , or later tried and installed new , but..... , for sure bricked , never
              unplug while flashing , hope you can find the pins and restore it , did you look into the Maskrom Mode
              Thread , maybe someone with same Box posted there , did you search on YT for Videos ??? , think your
              Bootloader is bricked , even SDBoot dont work or ,
              think UART is a good way to find bugs , but i am not a Pro ,
              Hi Everyone We have created this thread to collect all the NAND pin Short to Mask ROM Mode locations for all our members. Because firmware comes on android
              further good luck / gefattern
                Hi!! I know that your post is very old.. but the pins are these:
                Hope you can still unbrick it.. and hope to help others too...
                Tronsmart MK908II RK3188(non-T)
