Hello,
sorry for the mistakes don't speak english and i use google translate.
So I can't seem to get netflix in 1080p. so i try to install coreelec to run kodi https://coreelec.org/
With rufus, I put on usb key or sd card the correct image gxbb_p200_2G_1Gbit
Then I rename the correct file to dtb.img.
I press the reset button but I still have a black screen.
Is it possible to run coreelec or libreelec on this box and if so, what can you do?
my goal is to have netflix in 1080p for any other solution I am interested
Thank you
Thank you
