TV Box with "PURE" Android
    Hello,
    search a Box with pure Android. Pure Android because german SkyGo should be possible to install. Netflix and Prime in 4k would be nice but not must have..
    What Box can be recommended ? Should i buy one more Minix Neo U9-h or another Box.
    Greets
    xoBABAox
    Thx,
    i know, but on my Minix Neo U9-h SkyGo works without Problems, because its not Android TV. Stock Android 7 works on it. So i hope other Boxes with Stock Android works too.
    The U9-h is expensive and old...and no 4K for Prime and Netflix
      Originally posted by xoBABAox View Post
      Thx,
      If you really want a device for 4K Prime and Netflix then your best option is Certified and Licensed AndroidTV :
      According to website the SkyGo app works for Tablets, so if it works for Tablets it should also work for AndroidTV but you will have to Sideload it, the best and easiest way to do this is with Downloader app and the Aurora Store, more info on both can be found on YouTube.
        If your focus is PURE android and don't care about Netflix or Prime because you already have those on a Fire TV Stick or Xbox, then the best options are Single-Board-Computers (SBC) from either Radxa, Odroid, or Khadas. All 3 have a community with support that release Pure Android (AOSP) firmwares for their devices. SBC's take more time and effort to learn and if you want the easiest solution for Pure Android from a TVbox then go with either UGOOS or MINIX with the more powerful Amlogic S922 cpu.
          Thanks a lot, i look to the different options.
          Greets xoBABAox
            Personally, I think Minix Neo U9-h is a great TV Box that you can choose as a best option. It has a lot of super exciting features that are most convenient to you. You can even access FMWhatsapp apk by using this box.
              Thx,
              Hi ,
              Sky Go needs L1 DRM , or not , to look it Full HD or higher and why shall it not
              work on an ATV Version , there must be a App that works with ATV , because
              A7 is too old , why it schould not be possible to sideload it ,
              https://praxistipps.chip.de/sky-go-a...em%20Fernseher.
              further good luck / gefattern
