I cant go into recovery anymore nexbox a95x S905X
Need help please. I update myNexbox A95x 1/8G with the Minix freak OS rom and now i want to flash some another rom . My box has a reset pin in the av hole. So I have put the update on to the sd card ,I have pressed the reset pin and powered on the device it did not boot into recovery . I cant go into recovery anymore. its just turn on normalywhen i press reset buton. Another way i tryed to connect to pc use usb burning tool but PC can not recognize box. Please help How to go to recovery mode...Tags: None
Guest
1) Start burning tool with ROM loaded
2) Cross short pins on NAND before you plug in USB cable
3) you will heard it connect and burn ROM to the box.
I have done this million times with no problem... it's beyond bricked you don't have bootloader, it was erased... no worries.
Let me know if that works for you.... cheers
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Guest
It best to load up the stock ROM first then go from there . Not unless you are sure.... all the specs are correct with new ROM.
Here is a pic of the short location, looking at your pics. I would recommend using a mini test light ... as the resistance will not directly short the pins it will just cause enough
resistance to trip the nand reset on the power leg first. Hence, triggering the port connection so your ROM can load up.
1 Photo
Guest
Load up the stock rom first not unless you know the custom rom meets the specs. Burn stock rom, then do the custom rom after unbricked.
here is link to stock ROMS
here is what the mini test light looks like, you can find these online or at hardware stores... most likely on counter at checkout.. by the beef jerky.
1 Photo
Guest
Sewing needle on clipside of test light and the point is sharp enough the other side will hit the solder dot no problem. It will not light up because these are rated at 6-12v dc and you are just completing the circuit to trip nand reset. The resistance is all you need to trip it. Hope this helps!
One more thing the V6 board you have is indestructible! These are almost impossible to destory by design.
Samsung /Micron combo is rock solid
Originally posted by Kyle222 View PostIt best to load up the stock ROM first then go from there . Not unless you are sure.... all the specs are correct with new ROM.
Guest
Both of these custom roms work great on that box. And believe me you don't want to run 6.0 on that box... that is like a ferrari with glass belt tires. so much more potential. Do that
box some justice and run atleast 7.1.2 or higher. 6.0 is horrible
atvxperience.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf atvxperience.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Originally posted by Kyle222 View PostBoth of these custom roms work great on that box. And believe me you don't want to run 6.0 on that box... that is like a ferrari with glass belt tires. so much more potential. Do that
There are currently 2281 users online. 0 members and 2281 guests.
