MK823 Custom ROM thread
    Just a placeholder for now. mitchell4you, let's start the conversation here regarding my ROM and your testing...
    https://public.bay.livefilestore.com...ion.png?psid=1
    Link removed--
    First attemt (i post this link.. because i cannot access my inbox.. on the pc used to upgrade)
    Upgrade result: failed
    Some chinees error msg (see attached pic)
    D/l file 2times.. tried restore and upgrade 3 times.. same msg's
    Then tried stock fw.. that worked..
    Note.. please post .img files ziped or rar'ed..
    So, i can check if the d/l'ed image is not corruped..
    Cheers
      Originally posted by mitchell4you View Post
      Link removed--
      Cheers
      Ok. Will do. I'll also start out with simply unpacking/repacking the stock image to see if I am packing the image back correctly.
        Sounds good
          Sounds good
          Ok, check your PM. I've recreated the stock ROM (for the MOST PART :-) ), and repacked. Let me know if it flashes properly please.
            Ok Mitchell. Check your PM for a new link. This time I've only modified the boot.img. Let me know if it flashes and runs correctly.
