Help about root stock rom
Hello, few days a go i have received my K-R42, and i am for now satisfied how stock rom work. Just would like to know how to root it? There is tutorial on geekbuying, but files are encrypted in rar. I need root only for samba application. All other things work fine, lan, wlan, torrent, video playing. One more question, what version of xbmc you are using? On my xbmc there is problem with audio-video sync. Video is little bit faster then audio,and i would like to fix that. When i play video over mxplayer there is no sync problems. Only xbmc. Thanks in advance!Tags: None
Originally posted by gsavicic View PostHello, few days a go i have received my K-R42, and i am for now satisfied how stock rom work. Just would like to know how to root it? There is tutorial on geekbuying, but files are encrypted in rar. I need root only for samba application. All other things work fine, lan, wlan, torrent, video playing. One more question, what version of xbmc you are using? On my xbmc there is problem with audio-video sync. Video is little bit faster then audio,and i would like to fix that. When i play video over mxplayer there is no sync problems. Only xbmc. Thanks in advance!
http://www.freaktab.com/showthread.p...ooting-package
I tried it on mine (CS918), I had errors running the bat files but it rooted it anyway.
So it's good.
Good luck.
For driverinstallation at Windows you can use Moborobo
(BTW: needs I-net-connection and keeps drivers after uninstall)
The rest is the same... (TPSparkyRoot)RK3288 Devices
- Overview BOX (LINK !)
There are currently 3285 users online. 0 members and 3285 guests.
