X96 Max+ "System UI isn´t responding"
Hi! repeatedly when turning on the tv box that problem appears. When "close app" the system starts but without WiFi I have to connect it manually for it to work. I have flashed with several roms and the problem persists. Any solution you can help me with? Thanks!!Tags: None
Thoughts
1.keep unit running 24/7
2. Use "macrodroid" or "Tasker" to enable WiFi ( for example : On boot or If ssid is in range )
3.enable it manual? or use Wifi widget ( see Google play )
4. Init.d script ? (Requires Root )
Cheers
Note:
Some Fw have a launcher that requires online registration ( deviceId + Mac = valid or not )
If not valid launcher will fail "system ui is not responding"
-Sometimes on Allwinner units...this error also occurs If the "Cache" is full or you are "out of space" ( Ui not responding and WiFi drop )
--Try : Settings/storage/internal/cache ( emty cache..say yes )
mitchell4you
Hi! For two days the device works perfectly applying the suggestion number 2 "Use" macrodroid "or" Tasker "to enable WiFi (for example: On boot or If ssid is in range)" In a few days I will inform you if it continues like this! thank you very very much!!
There are currently 1107 users online. 0 members and 1107 guests.
