How to get Adobe flash player on mk802iv running Ubuntu 12.04
Originally posted by mitchell4you View PostWhat did you try ?
Did you d/l a deb file? (If yes did you do chmod? )
Perhaps
sudo apt-get install flashplugin-installer
test this
chromium-browser --ppapi-flash-path=/usr/lib/libpepflashplayer.so --ppapi-flash-version=11.5.31.105 --ppapi-flash-args=enable_hw_video_decode=0,enable_stagevideo_au to=0,enable_trace_to_console=0
you need download libpepflasplayer.so and put it into /usr/lib/, after that use the above parameter start chromium.
please clarify
Originally posted by hover View Postchromium-browser --ppapi-flash-path=/usr/lib/libpepflashplayer.so --ppapi-flash-version=11.5.31.105 --ppapi-flash-args=enable_hw_video_decode=0,enable_stagevideo_au to=0,enable_trace_to_console=0
Hi, sorry but I am new to this. please could you clarify what needs to be done step by step
I am struggling to get flash work on my mk802iv, tried stock broswer,puffin broswer, boat browser and photon browser none worked.
many thanks
There are currently 1896 users online. 0 members and 1896 guests.
