KII Pro S905D 2g ATV9
    KII Pro S905D LPDDR3/2g ATV9 build
    - WiFi - BCM4335 (Support for other WiFi chips on request)
    - RAM - LPDDR3
    - eMMC - 16g
    - DVB-Tuner - AVL6862 (currently not supported, no DTV support)
    Important - Switching from Android 6/7 to Android 9 must be carried out via UBT.
    If you already have Android 9 installed, you can perform an SDcard update.
    This build is based on this source code
    Credits @BPI Team
    Attention - Installation is only permitted on LPDDR3 devices! Support for DDR3/4 on request.
    Download KII_Pro_lpddr3_2g_4335_Pie
    Happy testing
    howto intall to android box
    firmware xxxxfile.tar
    thank somuch
      Open the *.tar.xz with 7-zip and just extract it. Install IMG as usual with AML Burning Tool
        i found it
        Good afternoon @ALL ATV9
        firmware (userdebug) for Q5.
        This assembly is intended for set-top boxes with the Fn-Link 6222b-srb WiFi chip (the same RTL8222BS).
        The version for BCM4324 (AP62x2) chips is in testing and will be released a little later.
        Updated u-boot loader
        - Added support for P211 (S905L) platform
        - Optimized RAM timing
        - Modified BL30 blob (special thanks to John Red for providing the patch), for an error in the incorrect determination of the chip id, which prevents further random MAC generation, the execution of the BL33 main bootloader code, leading to a cyclic reboot of the processor.
        Firmware based on Android 9, compiled from scratch
        - Added support for Megaphone and Beeline consoles by default, configurations are hardcoded in dtb (not tested yet)
        - Updated GAPPS
        - Fixed some incompatibilities leading to reboot of the console
        Please test. Logs are always welcome.
        - Initial installation via UBT only. Subsequent installations can be done using
        mSD card
        Also special thanks to @banderkin for providing logs and tireless testing.
        @ bars749 for testing WiFi + BT
        Download
        i intall S905L2 every thing ok scucessfull 100%
        but when start...only screen dark....hdmi connected
        thank so much
        may be only used for Q5
        not for another box android has cpu S905L2
          phankhanh86
          The bootloader in this firmware is designed for S905L devices with 1G RAM. If you have a 2G device you will get a black screen. But I'm not sure if you actually have a S905L2 SoC, otherwise the installation would fail.
            Originally posted by bumerc View Post
            phankhanh86
            no installation seccessfull 100% But tv still black screen
            can you change it for s905L2
            thank so much
              thank so much
              I need serial output uart/ttl
                i dont know UART/TTL
                i only user....
                so what can i do for you
                  Hello.
                  i have M8S DVB T2 S905D box. Is this firmware compatible with this box or if not could u make it for that box?
                    Originally posted by kompica051 View Post
                    Hello.
                    The type of DRAM memory is decisive..
                      So could i Flash one od those 2 firmware on my s905d 1gb ddr3 box? And which od those 2 firmware first for s905d 2gb or or second s905l 1gb?
                      does DVB-T work on those firmwares?
                      thanks
                        thanks
                        S905D 1G version is equipped with a 3D Nand (L95B). The bootloader driver supports this type of memory, but I was unable to test the kernel driver due to the lack of a test device. By default, only emmc support is activated, an installation on a 3D Nand device will fail.
                        DVB support has been compiled into this kernel, but AVL6762 is not supported.
                        You will need a different build for the S905L.
                          Thanks for answer but i am not so good it technic so if i Flash your firmware with usb burning Tool on my s905d 1gb would it work or it will be bricked? Thanks
                            it will be bricked
                              it will be bricked
                              Ok. Thanks for answer.
                              Would u make firmware for s905d 1gb?
                              thanks
