Since a couple of days I have a x7, plan to buy or an external drive or nas to store media files without a computer turned on and here comes the problem .....
The x7 I have it connected to the home network via wifi about 4 feet in a straight line without any interference involved, but (there's always a but) using the explorer esfile transfer rate does not exceed 800 or 900 kb and the mx player going to the movies 720 tugs and notorious stoppages . Entering through a browser that came with the ROM finless the issue of realentizacion is less noticeable , but still happening .
The problem I have is that if it's not on wifi , on the esfile explorer or the player.
I think the best would be to buy a NAS , but if these problems are by neo x7 would not have much sense and the best would be to buy an external drive for the neo .
What do you recommend? How is your setup ? Is there something I'm missing?
Facts to consider :
Minix neo finless x7 with rom 1.6 ( kernel_phja_720_vsfsam_cpu1800h_gpu600_ddr720 )
N 300mbps wifi router (configured on a free channel and 20hz - 40hz , probe in 20 and no change )
The PC has the files is wired to the router and have win7
Neo is connected to the router to 65Mbps and signal intesidad stop .
If I miss some information let me know and I add it , and if this is going Move it somewhere else please .
thanks
