I can no longer mount my external hdd drive
Hello everyone! I have traveled the entire forum and I see that it happened to nobody. I have x96 max plus 2 and I installed slimbox 10.5 pie. It is a wonderful rom, which I transform from such a rustic box into a luxury box! But from that moment on, I could never mount my external hdd drive again ... What could have happened? Did the same thing happen to someone? Thank you very much and greetings!Tags: None
Thanks Mitchell! It is Toshiba Canvio external Hard Drive 1TB without external power. It has no partitions and is on NTFS. Previously used the rom of Vasily Shevchuk
and I mounted it without problems, but since I installed slimbox 10.5, I could never mount it again .... Any pendrive takes it without problems, but the external hard drive never again. Thank you very much and greetings Mitchell!
Your harddrive is proberly not getting enough power (amp) to run
Options are:
Get a NAS
Use USB port from your router, then share the contens from your HD ( SMB / FTP / ... ) to your network
Get a Sd-card ( the go up to 2TB )
External powered Harddisk
Use a Cloud based file sharing site
Get a OTG Y-cable ( female usb --> Data and Power male usb connector )
Get a external powered Hub
Get a Displaylink device ( its like a external hub, but witth more options )
Share HD contents from a PC ( plex server/ftp/smb/.. )
Just some thoughts
There are currently 1232 users online. 0 members and 1232 guests.
