Anyway.. as the supplier support seems to have dried up across all JUSTOP products, and their forum seems to be dying, I thought I would have a go at customising the image file.
There are a lot of clever people out there who have worked out how to get into the various Android images and there is a mountain of information/tutorials on how to do it all. If you can join up the dots then it really is possible to unpack your downloaded image file and make all the changes you need. Then repack the image and load it back onto the box.
I have stripped out all the apps that I don't want and loaded up the apps that I do want. Changed the setup config eg: UK/english/GMT and switched off the TvdLauncher so that it boots as a normal Android tablet. It works faster than ever and doesn't need so much configuration at first startup.
If anyone is interested on the theme of customisation then we can together find all the switches and levers to get this box customised to the max. I can help with the image unpack/edit/repack bit but I don't want to reproduce the clever stuff that others have done. I can point to their work and help with some of the more difficult bits though.
This is the TV Box that I am talking about:
JUSTOP Android 4.0 TV Box - MPA040BKT
JUSTOP_A054_V1.8.1_20130809_ytb_fix.img << The most stable image file
OK I know it's an old box now but I still use mine and the latest ones don't seem much better.
