X88 PRO 20 RK3566 Android 11 RK3566 8GHz 2.4G+5G WIFI Gigabit LAN Voice remote
    X88 PRO 20 RK3566 Android 11 RK3566 8Ghz. 2.4G+5G WIFI Gigabit LAN Voice remote
    Available in 3 Flavours:
    4/32GB, 8/64Gb and 8/128GB
    As Found
    Running on the latest Android 11 OS, the X88 PRO 20 features the Rockchip RK3566 chipset which is the
    successor to the Rockchip RK3288 SoC and outperforms it significantly , with quad-core Arm A55 CPUs ( 4x Cortex-A55 @up to 2 . 0GHz ) and an Arm Mali G52 GPU . RK3566 SoC supports 4Kp60 H 264 / . 265 / VP9 and other formats HD decoding.
    In addition to the aforementioned Rockchips chipset , the TV Box comes with 4GB-8GB RAM
    2GB-128GB eMMC . The PRO 20 also supports Dual-Band 802 . 11ac , Gigabit Ethernet , and Bluetooth 4.2.
    Geekbuying
    Specification as Found
    Brand: X88
    Model: X88 PRO 20
    System: Android11.0
    CPU: Rochchip RK3566
    Core: Quad Core Cortex-A55
    RAM: 4G RAM
    RAM Type: DDR3
    ROM: 32G ROM
    Max. Extended Capacity: TF card up to 32GB (not included)
    TV Box Features: 5G WiFi
    Color: Black
    Decoder Format: HD MPEG1/2/4, H.265/HEVC, HD AVC/VC-1, RM/RMVB, Xvid, RealVideo8/9/10
    Audio format: Supports MP3, AAC, WMA, RM, FLAC, Ogg and programmable with 7.1/5.1 down-mixing
    Video format: Supports * .mkv, *. Wmv, *. Mpg, * .mpeg, * .dat, * .avi, * .mov, * .iso, * .mp4, * .rm and * .jpg file formats
    Photo Format: HD JPEG/BMP/GIF/PNG/TIFF
    Support 5.1 Surround Sound Output: No
    5G WiFi: Yes
    WIFI: 802.11 b/g/n/ac
    LAN: 1000M
    Bluetooth: Bluetooth 4.2
    Power Supply: Charge Adapter
    Interface: DC 5V,HDMI,OPTICAL,RJ45,TF card,USB2.0,USB3.0
    Language: Multilanguage
    Other Features: 1.Network Function: Miracast, AirPlay, Skype Chatting, Picasa, YouTube, Flicker, Facebook, Online Movies, Etc. 2.Language: Chinese, English, Germany, Japanese, Korea etc. 3.ota: Support OTA Update
    HDMI Version: 2.0
    Power Type: External Power Adapter Mode
    Power Input Vol: 5V
    Power Adapter Output: 5V 2A
    Product weight: 0.1100 kg
    Package weight: 0.5150 kg
    Product size (L x W x H): 10.00 x 9.80 x 2.00 cm / 3.94 x 3.86 x 0.79 inches
    Package size (L x W x H): 19.50 x 13.00 x 6.50 cm / 7.68 x 5.12 x 2.56 inches
    Package Contents: 1 x TV box, 1 x Adapter, 1 x Gift Box, 1 x Voice Remote, 1 x HDTV Cable, 1 x User Manual
    Geekbuying
    Available in 3 Flavours: and a few coupons if they help
    8GB/128GB
    $99.99 after coupon:5SVNTL1F
    https://www.geekbuying.com/item/X88-..._term=X88PRO20
    8GB/64GB
    $89.99 after coupon:5SVNUHQH
    4GB/32GB
    $56.99 after coupon:5SVNYANN
      I just received the X88PRO20 TV box.
      I am disappointed. It can't play 4k h265 video. I have a green screen and autoframerate don't working.
      Android v11 firmware is very bad, hope there will be an update soon.
      Click image for larger version  Name:	x88pro20_error.png Views:	0 Size:	154.2 KB ID:	823037
      • mo123
        mo123 commented
        Editing a comment
        Never buy these no name tv boxes as they will have bugs that will never get fixed.
        These manufacturers only check if the box turns on and gets a picture, no checks for video playback or sound are done.
        The chances are very slim that your device will get working firmware.
      • mo123
        mo123 commented
        Editing a comment
        If that is RKMC then uninstall it.
        It was made for Android 5/6 and discontinued several years ago.
        Not sure why the manufacturer includes such non working software, they clearly don't know what they are doing.
        Use instead
        Frame-rate switching is not supported on this device.
      Originally posted by nic029 View Post
      Are you using the preinstalled Kodi player? IF so then uninstall that sh*t version, it creates many problems, and install a completely fresh Kodi 19 from the Play Store.
      A new kodi may help, but like Mo said if the Firmware itself is bad then you most likely are stuck on that firmware and won't get an update.
        Thank you for your answers.
        No kodi preinstall on this tv box.
        I tested with this kodi: http://mirrors.kodi.tv/releases/andr...-arm64-v8a.apk
        I have the same issue green screen when I play video 4k with X-plore-4.26.00 . No issue with videos HD 1080.
        rk3566 is fast and does not heat up. I really think it's android v11 issue.
        I have not found a tool to make a backup of the rom. So at the moment I am stuck with this firmware which is not rooted.
          Enabling superuser in android 11:
          It's true I do this on the X96 max plus console on android 11 ,which I posted from project treble.Maybe it's different here.
            Hi ,
            a shame to China , that they let this happen , all this uncorrect Manufactors , without Support ,
            greetings / gefattern
              More coupons:
              X88 PRO 20 is with RK3566.
              8GB/128GB
              $94.99 after coupon: IGRAAL5
              8GB/64GB
              $89.99 after coupon: 5SVNUHQH
              4GB/32GB
              $56.99 after coupon: 5SVNYANN
                Hello,
                I just saw this video on YouTube that explains how to update this box https://www.youtube.com/watch?v=rKdRiwBqM9I
                They use DriverAssitant v5.1.1 and FactoryTool v1.72.2 tools to burn firmware "X88pro_rk3566_4d8_11.0_ap6255_20210401_r1(X88 pro20).img".
                I can't find these versions of DriverAssitant, FactoryTool and firmware. Does anyone have these versions for me?
                Thank you for share.
                  I am sorry very old version. Tool out of date.
                    Hello,
                    ...DriverAssitant v5.1.1 and FactoryTool v1.72.2 tools...
                    [YandexDisk]
                      Hi guys
                      watch this review
                      so,do not buy for a moment!
                      wait couple of time to resolve some of BUGs and video play performance 4K/H265
                      (green-screen issue;this issue from RK3399 too!!! and its not affected of Android version)
                        Yes like all things new.....Its easy to say how bad it is or what it cant do
                        We are the Beta testers.....
                        Pressure on suppliers.....will ensure it will work
                        All in due Time
                          in the past of couple of years that I'v been used many "RK3399" devices and we were knew it how they were!
                          -Firmware;not support ever!
                          -Green-screen issues for 4K videos!
                          and many other BUGs to
                          and where is the bug-fix firmware?? nothing as well
                          paid for this Boxes at least $ 120/150(min) too!!
                          -"mo123" explained very clearly above and its totally true
                          and now RK3566 recently on stage,seems that we have to wait more detailed real user reviews(instead FAKE reviews as well)
                          GBest/Geek/Ali/Bang etc., if you read this reviews;well all this BOXes super super super hahhaaaa
                          I love it those CHINESE
