Need help with H96 Max H616 4/32.
Box stopped turning on. It is impossible to flash again. PhoenixSuit detects that the device is connected. But when you try to flash after a few minutes, the program reports that the firmware download has failed. Could you tell me how to put the box in mask rom mode? What contacts on the board need to be closed for this. Memory Toshiba THGBM9G8T4KBAIR.Tags: None
Greetings
Board is similar .....
Sort of...
Nand is different than Toshiba is SCY SMD Nand
However Toshiba Nand short sometimes 29,39 or ...unknown
Maybe wont help Maskrom Mode unidentify..
If Phoneix Suit detects that is good thing..
I just tested latest Version Phoneix Suit_V1.10
And PhoneixUSBPro_V4.0.0
With Success both times
Held in Reset Button with toothpick and connect USB to PC
All good
Took approx 4mins 48s
Maybe Unistall Versions you Have and download Latest Versions
I used // androidmtk for download of Utilityies
There is also Phoneix Card Maker V3.1.0 you can Try
I had no success with Latest Version of LiveSuitPack V 1.11 would Detect Device but File is corrupt....etc...
which is not Correct / same image worked in USBPRO and PhoneixSuit.
Most important is compatible Firmware image
Also length of USB cable can cause issues
Good Luck
Happy Testing
Okay
What is on Plastic cover Case H96 Max
Which image are you testing?
Testing other images with same spec as your box if you havent allready ?
I just tested image for your Box on my Wechip
Bootloop
Then Tested image for T95 10.1.12
Works/no wifi/remote key functions not all work
Then tested image for T95 10.1A24_20210315
Works perfectly all functions
Same as WEchip Image ZXWeChip-V10-A21
From Images you posted i see H616- V10 printed on board(What is date printed underneath,Heat Dissipate is covering)
Maybe test WeChip image if you have not allready
Also from Image right below USB0 is serial pinout DEBUG is printed
If you have U-art maybe can communicate with CPU
The Nand Toshiba
Imagine walking along beside a picket fence skipping a stick from slat to slat
Now apply that theory to Nand chip
Open up PhoneixUSBPro_V4.0 load image
Connect Male to Male
Start at 1 side of Nand and slowly,ever so gently
Skip from Pin to PIN shorting as you Go
Test Clk to ground under CPU Is cluster
Use GND from Serial or metal case of SD Card Reader
Now short components to GND one at atime
Maybe will work
If you Have success please post For Others
Happy Testing
Hi
You are welcome
Did not know you had posted there
I directed you there so you could get a visual on what to short circuit with what( Your post #7)
There are some great pics/images with pinouts identified and what tool used
Test leads from multimeter are good for bridging
Or tweezers
Or paper clip .....maybe
We use Automotive 12V test Probe
Aligator clip one one end
Nice fine point on Probe
MaskRom Mode is last resort after you have exhausted all other options...
Further Good Luck
Happy Testing
Hello there.
I have same problem with this model.
I think there is no way to upgrade the firmware! Cuz it seems the board could not read the EMMC !
But i just found a ways to use the motherboard as a TV BOX !
I Burned a bootable MicroSD as a EMMC with the firmware of that and when I connected the power to my device it started to loading and working!!
But now i have new problem
I broke a SMD piece on the board by a mistake nad now i dont have any idea about its specification!
If there is any datesheet or a High quality picture of the board maybe i could find same piece and repair it !You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by VVV22 View PostI can't find the data sheet.
It seems these (16GB) boards come with different NAND's: Toshiba THGBM9G8T4KBAIR (@VVV22), Sandisk SDINADF4-16G (@mAtvXk), BiWin bwctasc21g16g (mine on board H616-V10 2020/06/21 ..2050).
Datasheet is for Sandisk one. Page 21-22 describes the pins.
I understand we are supposed to short Data0 and Data1 (A3 & A4)?
There are currently 2724 users online. 0 members and 2724 guests.
