x96 android stock firmware 7.1.2
    Hello, I just burned the stock firmware android 7.1.2 on my x96 box, and it's better than the 6.0 version, it's rooted by default.
    You can download from here:
    open
    https://pan.baidu.com/s/1b0PCrc#list...55616658429342
    input
    password:hp7u
    find
    7.1 android aml_upgrade_package.img 1.46G 2018-08-1316:25
    UPDATE:
    I upload the img file to mega, you can download it here: https://mega.nz/file/IjxDHCBS#442t8w...B7kffjgS1eFv1A
    It worked for me. Thanks a lot
      I've been searching for a firmware to flash into my X96 S905x chip. Is it the right file (.img?) for me to use Amlogic USB burning tool to flash it? I'm not talking about updating my current firmware.
        Originally posted by bthoven View Post
        Yes, it's the official android img firmware for X96, not a zip update package, you can use the Amlogic USB burning tool to flash your X96 box.
          Thanks. I've flashed it successfully.
