Netflix in HD for Mecool Google Certified Devices
    I now have a Netflix APK that runs in 1080p with DD+ audio. It runs the Android TV OS version so NO mouse required. It works on some of the Mecool Google Certified devices............
    KD1 Netflix 1080P with DD+ audio.
    KM6 Deluxe Netflix 1080p with DD+ audio
    KM1 Netflix 1080p with DD+ audio
    KM8 Google Certified but Netflix will NOT run
    M8S Pro L Widevine Level 1, Netflix would not run.
    KM9 running KM9pro, Widevine level 1. Netflix would NOT run
    Need it ! I want to test!
        Damned! Finally! I can confirmed that the above works well with KM1 DELUXE with 5.1 passthru!
        Thanks buddy!
          Thanks buddy!
          Thanks for the confirmation.
            Bro clarkss12
            I'm also pleased and delighted to report that my other KM9 Pro running on Android 9 is working perfectly with the app you shared. Both runs well, auto play next HD episodes automatically, no problem with search buttons and play almost immediately in HD format smoothly with no stuttering at all, DD+ audio
            Thanks again Bro!
              Next is await for my Sis to bring her KM3 for me to test this weekend although others have reported it doesn't work on theirs...?
                HD Netflix confirmed:: NO mouse required!
                For Mecool Google Certified devices
                KM9 Pro Netflix 1080p with DD+ audio
                  https://drive.google.com/file/d/1SdT...ZWuAE5Fwq/view
                  Hi, I have a Mecool K5 S905X3 smart box and I have installed this version of Netflix and unfortunately I can only access HD and non HDR content. Do you know why? Do I need to change any settings or the device is not compatible? Thank you
                    Yes, because it's a hacked app.
                    You need a Netflix Certified device to play 4K and HDR, no hacked app can bypass those limitations since Netflix has strict security.
                      You ought to be grateful you're now able to access HD 5.1 via the remote. However if you need hdr suggest you look up the all new KM2 which is officially certified Netflix 4k
                      I can also confirmed that sadly even KM3 is not able to use this apk for strange reason although its Google verified with L1 widevine
                      Enjoy your box
                        nice, we will try thanks
                          It works perfectely even on my Mecool KT1 dvbT2 (only for HD contents, not HDR). After i made a firmware reset, the netflix apk was deleted from OS, this one i think is the same was installed by factory original setup (but must be installed because is not in the firmware). Thank you for sharing it.
                          Hi
                          Alex
                            After I installed this file, it was a black screen after booting up and couldn't be used because the firmware Google service originally used by my machine was too old to download
                              Thanks buddy!
                              hi can i get a link for this
