Flashed bootloader on Vontar Z8 Arc (M8S Pro)
So I think I've made a mistake by flashing TWRP to the recovery partition on my Vontar Z8 Arc (S912 DDR4, same as M8S Pro), when I try to use the amlogic burning tool after using the reset button on the bottom, it boots to TWRP instead of being recognized by the tool. In the TWRP version I'm using I can't do anything useful like flash a newer ROM to the device. Is there a way to get the original bootloader back or otherwise make TWRP useful? I'm on an ATV 7.0 ROM and want to update to the newer ones available.Tags: None
There are currently 2486 users online. 1 members and 2485 guests.
