How to Unbrick rk3228a micron jwa60
Can someone know how to unbrick this tv box. I tried to install armbian focal current on it using multitool provided by the tutorial in the site of armbian. then after doing the tutorial i shut it down then reconnect the power jack the blue light turn on but no signal on my monitor i tried to reflash using rk batch tool but it does not been recognized by my computer even i already installed the driver. (sorry for my grammar) I cannot do maskrom mode because the storage installed is BGA. Does someone know another method to unbrick?You may only view thumbnails in this gallery. This gallery has 4 photos.4 PhotosTags: None
First of all, I am not an expert. (I am a newbie who wants to help based on what has worked for me)
apparently we have the almost identical box.
I'll tell you what I did, I made it work but then it failed.
locate holes E and G or C make a bridge between the 2.
then launch Android Tool v2.7.1 (press resert and connect usb)
start update it will give you an idb error
* change the advanced functions to the maskmode.
now remove the jumper cables and start the process of install firmware.
It gave me problems, the recovery does not work on the device.
do not try to access it or it will result in brick.
at the bottom of the post (RK3229 Devices)
someone uploaded recovery
and I don't know and I can't find how to install .img
try to find some fimware that does not demand much.
* I installed one that appeared a universal type logo only turned on 1 time then it bricked.
another idea that I have
Rockchip Create Upgrade Disk Tool v1.53
intert the sd select only sd boot.
once finished
press reset connect it to the pc
should change to mode.
Take out the sd and try to update on the pc.
Originally posted by tomsavini View PostFirst of all, I am not an expert. (I am a newbie who wants to help based on what has worked for me)
once finished
There are currently 1606 users online. 0 members and 1606 guests.
