First, did open the box and drill a hole:
Must be carefull little pieces of metal dont go inside boardcircuit, and short something!
Then, install the BNC female, i did buy from 5 bucks on BG...
Remove the original conector antenna, put a little tap, and conect the new antena to board...(sorry no pictures)
Installed and mounted, the new BNC:
And the new Wi-fi antenna:
Almost like original!!
And did it works? Well i have 100MB`s fiber, with a router about 10 meters. Originally as posted above, i get
lot of breakes on conection, sometimes did refuse to conect, with a signal way above 1Mb`...a complete disgrace!
Here are the results:
About 160% increase signal! Also, wi-fi conects almost as speed light!
Im very happy with this mod, works very well, is not complicated, easy and cheap. No rom`s, mods, or whatever....
Also, i can remove antenna any time, if i want put the box on my pocket.
Hope you guys did enjoy!
