Help identifying wifi Chip
Hi , looking to try identify my wifi chip . I believe its broadcom . The box is Qbox S905x and i want to upgrade to pie .Sticker inside the box seems to indicate broadcom 4335 but wifi will not work in pie on any of the universal bcm roms . Attached is a photo of the chip which has the marking sm63350911 any help would be appreciated .Last edited by jimennis; 14 May 2021, 15:43.Tags: None
Here is the link to the files i used , after installing slimbox latest s905x atv using Esfile explorer i replaced the 6335 folder and Bluetooth in their entirety and fixed the permissions of the folders and the files ,then proceeded with the remaining files fixing permissions as i replaced them reboot and both wifi and bluetooth work . https://drive.google.com/drive/folde...pu?usp=sharing
Originally posted by jimennis View PostHere is the link to the files i used , after installing slimbox latest s905x atv using Esfile explorer i replaced the 6335 folder and Bluetooth in their entirety and fixed the permissions of the folders and the files ,then proceeded with the remaining files fixing permissions as i replaced them reboot and both wifi and bluetooth work . https://drive.google.com/drive/folde...pu?usp=sharing
you need root , locate your original folders using esfile explorer and make a backup of them, take a note of the folders permissions using file explorer , then just copy paste and overwrite them with the new folders , then you have to fix the permissions on files within the folders to -rw-r-r using esfile explorer one by one and finally fix both folders permissions to what you noted
I had managed to port the WiFi drivers and now using slimbox Android 9 on it teatv download
​hellodear.in
​Last edited by amrishhpuri; 12 December 2022, 15:07.
There are currently 2104 users online. 0 members and 2104 guests.
