What are the ways to install Android TV apps on Android box?
For example, on the AX95DB Android box there is the Android TV PlayStore, what should I do?
There are applications that can be installed from the Android Play Store in TV box mode (use by remote control) or in tablet / smartphone mode. How to force the installation of these applications in TV box mode (remote control) on Android box.
Thank you.
