i have beelink gt king , no signal on screen and the device is bricked
tried to make it by usb method , not detected , sd card not detected
couldn't try the boot card maker as it needs u boot file which i didn't find on the stock firmware !
so if someone can locate it for me i appreciate it
on the other hand if someone can tell me what pins to short to unbrick the device it will be much better
