problem wifi R90 RK3229 Please help
    Hello
    I installed a ROM for R90, but it did not work because of the difference in the boot, so I opened the cover to enter the Mask rom mode and toch between Pin 7 & 8 and I actually succeeded in reinstalling another ROM, but when I opened the cover, the Wi-Fi wire was automatically cut off due to poor welding quality, After installing the ROM, the WiFi did not work, I tried to install it with my finger in the same place where it was soldered, but it did not work, I want to help guide me on how to install the wires with the correct place
    NOTE : i check this rom update-0112-8.1atv-leelbox-done before open cover its work wifi but after cut off not work
    Wifi : sv6051p chip
    Board : rk3229 _mxq_5g_bt v1.0
    please help
    You may only view thumbnails in this gallery. This gallery has 5 photos.
      Originally posted by mAtvXk View Post
      I know how to soldering , but I don't no the location !!
      Do you know where the location in my board ?
      in this video it's different board and my board different .
      Please indicate the identification of welding in the board
        Observations From images posted
        Image with red arrow pointed at Red Circle
        Solder the outer Braided Shield there
        Solder the inner core/single conductor to Solder Blob left of Red Circle
        Probs best to remove both solder blobs and expose /clean pins/contacts
        Good Luck
        Happy Testing
          Good Luck
          Happy Testing
          i do but not work !!!!
          if any boady have diagram for this board please put it here
            i fixd thanks to help
