Help! All USB ports and remote control stop working
Hi, all USB ports on GS king pro and it's remote control stop working. I can't navigate at all, I did a full reset but still every mouse/keyboard/track pads I plug in the ports does the work. Is this a hardware issue or can installing a wrong recovery. img do this? Thank you.Tags: None
Originally posted by TheBlackening View PostIf you have a male to male USB cable, try connecting the box to a computer to check if the computer recognizes the box.
Or try flashing a stock ROM through the SDcard method.
???The USB is to PC is throwing error messages like "device unrecognized etc" as was trying to flash new firmware via USB burning tools. Even pressing the reset pin hole button underneath the GS king pro.
Haven't tried the SDcard method so I'll give it a try and report back.
Originally posted by TheBlackening View PostHopefully it's just a windows incompatibility, but, I'm sorry to say it's not looking good so far.
Good luck on the sdcard method, i hope it works. Good luck.
Originally posted by TheBlackening View PostRight now the only thing that occurs to me is opening it and take a look at the electronics on the board to see if there are any obvious faults, for example, any burned capacitor, which would be an easy fix at a electronics repair shop.
There are currently 2422 users online. 1 members and 2421 guests.
