This firmware for Tanix TX3 S905X3 4-64GB is from the firmware designed for Tanix TX5 S905X3 Plus Deluxe Edition under the name Tanix-Box_com-TX5PLUS-20200426.img
It is tested in the TV box Tanix TX3 S905X3 4-64GB.
Theoretically, it should work properly in a TV box Tanix TX3 S905X3 4-32 GB. (Install this firmware on such a TV box only at your own risk / nerves.)
This firmware is not intended for TV Box Tanix TX3 S905X3 2-16GB.
Changes in Tanix TX5 Plus Deluxe Edition firmware:
- added bluetooth and wifi for Tanix TX3 S905X3 4-64 GB,
- I didn't make any other changes.
Firmware characteristics:
- it is Android 9, full/normal Android (it is not Android TV/ATV),
- files can only be uploaded to a USB key via the pre-installed FileBrowser application,
- YouTube Red is more stable to stable,
- more stable wifi connection,
- Apple music and HBO Go (Slovak region) work in non-root mode,
- the original firmware did not start my Slovak bank application: this firmware will start my banking application correctly,
- root / noroot switch,
- Alice UX lite edition launcher,
- RGB 8 bit color space, for old TV, if is pink screen,
- AnTuTu benchmark is 74 691.
It is an "img" firmware for the Amlogic USB burning tool. If you are new to uploading firmware to a TV box, watch some YouTube video on how to use the Amlogic USB burning tool.
Firmware in zip file with name "For_Tanix_TX3_S905X3_4-64GB_from_TX5PLUSdeluxeedition-20200426.zip" for download is on this link:
https://drive.google.com/file/d/1EzR...vDy_MVf8_/view
Screenshots:
Launcher Alice UX lite edition
About
Color space
Root/noroot switch
Good luck
