8th Generation Intel i5-8279U:
Beelink SEI8 Mini PC Equipped with 8th Generation Intel Coffee i5-8279U Processor (2.40 GHz, up to 4.10 GHz,4 Cores 8 Threads, Supports 6M Intel Smart Cache) 14nm lithography technology. 28W High-performance version, a fast, smooth, and power-saving mini PC, It can satisfy your diverse scenarios' use such as entertainment, games, office, etc.
Intel Iris Plus Graphics 655 & Support 4K Dual Screen HD Display:
The mini desktop computer SEI8 Supports 4K HD (4096×2304) ultra-high-definition content, 4K@30hz videos playback from YouTube Netflix are always smooth and work well. you can enjoy 4K Web surfing, video playback, watching TV, home theater, and enjoy the entertainment with your family. Dual HDMI Ports .easily connecting 2 monitors, reduce waiting time, efficiency doubled Work.
Powerful Storage & FASTER RUNNING SPEED:
16GB SO-DIMM DDR4 2400MHz Memory(Can Upgrade to 32GB ),512GB M.2 NVME SSD( 1 accessible SATA3 HDD 2.5in slots). It could deal with multiple tasks and windows easily at the same time smoothly run your games, photos, and video-editing applications.
More Ports & Efficient heat dissipation:
Mini Desktop PC Beelink SEI8 28W High-Performance version, including Gigabit Ethernet LAN (RJ-45 port)| WiFi 6 (802.11AX) and Bluetooth 5.0 combo (Supporting Gigabit file transfer speeds)USB 3.0*4, HDMI*2, Audio Jack (HP&MIC)*1, DC Jack*1, TF Card reader Interface*1, Type-C*1, Efficient heat dissipation cool down the computer's hardware, reduce hardware loss, and make the computer's response speed faster. with strong heat dissipation capacity, almost no noise.
Operating System & Beelink SERVICE:
The Beelink SEI8 Micro Desktop Computer is Pre-installed with Windows 10 Pro OS. They are three accessories we will give you together, Wall-Mounted bracket, HDMI 80CM&20CM 1.4, and Adapter 19V/3A 57W. The Wall-Mounted bracket can help you easily fix the mini computer to the back of the monitor and saving space.| All of our products obtained FCC, CE ROSH certifications. We offer a 1-year free warranty, and 7 Days/ 24 hours serving.
https://www.bee-link.com/products/beelink-sei-8279u
