I have a TCL 55S434 that's running Android TV. When I first bought the TV I got curious and plugged a USB hub into the USB port and hooked up game controllers, a logitech wireless keyboard, removable storage. And I found that the firmware it was running would allow control via a game controller, and the logitech wireless keyboard worked as if it was plugged into a computer. Awesome stuff. But there was an manufacturer update that seemed to remove that functionality. I tried different wireless controllers, different wireless keyboards, and the closest I got to success was getting an Xbox 360 wireless adapter for Windows to work, although it won't pair any other controllers except for 1. And there have been problems pairing various bluetooth controllers, namely the 8-bitdo line. Although the 8bitdo controller DID work connected wired.
I've used homespun Android ROMs for a couple other Android TV devices before I decided to experiment going this route. But I did a search on FT to see if there was any investigation into this. And to my surprise, there's not.
Is there anyone out there messing around with this? If not the TCL line, Sony? Hisense? I'm curious.
Thanks for reading!
