Model | ZIDOO M6 Mini PC |
SOC | RockChip RK3566 |
CPU | Quad-core 64-bit Cortex-A55 processor, 22nm advanced technology, CPU clock speed up to 1.8GHz |
GPU | ARM G52 2EE |
Support OpenGL ES 1.1/2.0/3.2?OpenCL 2.0?Vulkan 1.1 | |
Embedded high-performance 2D acceleration hardware | |
NPU | 0.8Tops@INT8, Integrated high-performance AI accelerator RKNN NPU |
Support Caffe/TensorFlow/TFLite/ONNX/PyTorch/Keras/Darknet mainstream architecture model. | |
VPU | Support 4K 60fps H.265/H.264/VP9 video decoding |
Support1080P 100fps H.265/H.264video decoding | |
Support 8M ISP | |
RAM | 2GB / 4GB(standard)/ 8GB LPDDR4 (optional), eMMC5.1 |
32 Bit width, support full link ECC | |
Internal Storage | 16GB/32GB(standard) / / 64GB / 128GB eMMC (optional) |
TF-Card Slot x1 | |
Hardware Parameters | |
Ethernet | Gigabit Ethernet is supported?RJ45, 100M/1000M bps? |
WiFi | Support WiFi6 2.4GHz/5GHz dual band WiFi?802.11 a/b/g/n/ac/ax protocol, downward support WiFi5 (WiFi6 is optional) |
Support BT5.0 | |
5G Broadband | Support 5G and 4G LTE module full netcom (network module is optional) PCIe×1 |
Display Port | 1 × HDMI2.0, support 4K@60fps output |
Audio Ports | 1 × HDMI audio output |
1 × Optical output | |
1 × 3.5mm headphone output (Analog L R output) | |
USB | 1 × USB OTG ?2× USB2.0 HOST |
RS232 Debug Port | Support RS232 protocol debug port |
TF Card | Support 64GB-128GB |
IR IN | IR infrared remote control receiver |
Power Supply | DC 5V 2A |
RS232 Port | 1×RS232 port |
Extension Ports | Display ports?1 ×LVDS(RGB888 RGB666), 1 ×MIPI CSI, 1 × MIPI DSI, support 1920*1080@60fps output?or dual channel 1 × MIPI DSI 2560*1440@60fps), 1×eDp(1.3 interface 4 wire 10.8Gbps up to2560*1600@60Hz) Camera: 1×MIPI-CIF Camera Microphone: Microphone array, MIC Others: I2C, UART, ADC, GPIO, PCIe, I2S, VFD, Speaker, G-Sensor. |
Built-in TCON-EBC, support RTC time circuit (cell battery could be built in) | |
Software Parameters | |
System | Support Android 11.0 , (Ubuntu 18.04, Buildroot + QTStation OS custom system? |
Other Parameters | |
Device Dimension | 166*102.5*32mm |
Mainboard Dimension | 158*95*1.6mm |
Operating Temperature | -10??60? |
Storage Temperature | -20??70? |
Storage Humidity | 10%?80 % |
AI Scenarios | M6 has built in independent 0.8T NPU processing, AI computing power is strong. It is the first to support the function "canvas in the air" in the industry, which can be widely used in AI scenarios like intelligent interaction, face recognition, online conference, face tracking, body recognition, gesture recognition etc. M6 comes with ePTZ function, which brings users a better experience in video call scenarios. Brand-new AI interaction logic will make the traditional TV be a smart screen. |
Various Applications | More intelligent applications are supported including 5G 4K real-time playback, video conference system, smart teaching, office applications, dual screen digital signage, facial recognition payment systems, edge computing, shopping mall guides, leisure and entertainment, smart dining, airport information, intelligent robots, security systems, industrial control, outdoor advertising and multi-screen applications etc. |
ZIDOO M6 RK3566 4G LPDDR4X 32G eMMC SUPPORT WIFI6 5G &4G LTE module?OPTION)
Tags: None
ZIDOO M6 RK3566 4G LPDDR4X 32GB eMMC WIFI 6 & WIFI 5 OPTION , 5G and 4G LTE OPTION
Advertising machine, digital sign, intelligent self-service terminal, new retail intelligent terminal, smart business display, smart meal board, shopping mall guide, floor advertising, smart hospital numbering, AI development board for leisure and entertainment, with NPU
https://www.zidoo.tv/Product/index/m...McQ%3D%3D.htmlSOC RockChip RK3566 CPU Quad-core 64-bit Cortex-A55 processor, 22nm advanced technology, CPU clock speed up to 1.8GHz GPU ARM G52 2EE Support OpenGL ES 1.1/2.0/3.2?OpenCL 2.0?Vulkan 1.1 Embedded high-performance 2D acceleration hardware NPU 0.8Tops@INT8, Integrated high-performance AI accelerator RKNN NPU Support Caffe/TensorFlow/TFLite/ONNX/PyTorch/Keras/Darknet mainstream architecture model. VPU Support 4K 60fps H.265/H.264/VP9 video decoding Support1080P 100fps H.265/H.264video decoding Support 8M ISP RAM 2GB / 4GB(standard)/ 8GB LPDDR4 (optional), eMMC5.1 32 Bit width, support full link ECC Internal Storage 16GB/32GB(standard) / / 64GB / 128GB eMMC (optional) TF-Card Slot x1 Hardware Parameters Ethernet Gigabit Ethernet is supported?RJ45, 100M/1000M bps? WiFi Support WiFi6 2.4GHz/5GHz dual band WiFi?802.11 a/b/g/n/ac/ax protocol, downward support WiFi5 (WiFi6 is optional) Support BT5.0 5G Broadband Support 5G and 4G LTE module full netcom (network module is optional) PCIe×1 Display Port 1 × HDMI2.0, support 4K@60fps output Audio Ports 1 × HDMI audio output 1 × Optical output 1 × 3.5mm headphone output (Analog L R output) USB 1 × USB OTG ?2× USB2.0 HOST RS232 Debug Port Support RS232 protocol debug port TF Card Support 64GB-128GB IR IN IR infrared remote control receiver Power Supply DC 5V 2A RS232 Port 1×RS232 port Extension Ports Display ports?1 ×LVDS(RGB888 RGB666), 1 ×MIPI CSI, 1 × MIPI DSI, support 1920*1080@60fps output?or dual channel 1 × MIPI DSI 2560*1440@60fps), 1×eDp(1.3 interface 4 wire 10.8Gbps up to2560*1600@60Hz)
Others: I2C, UART, ADC, GPIO, PCIe, I2S, VFD, Speaker, G-Sensor.Built-in TCON-EBC, support RTC time circuit (cell battery could be built in) Software Parameters System Support Android 11.0 , (Ubuntu 18.04, Buildroot + QTStation OS custom system? Other Parameters Device Dimension 166*102.5*32mm Mainboard Dimension 158*95*1.6mm Operating Temperature -10??60? Storage Temperature -20??70? Storage Humidity 10%?80 % AI Scenarios M6 has built in independent 0.8T NPU processing, AI computing power is strong. It is the first to support the function "canvas in the air" in the industry, which can be widely used in AI scenarios like intelligent interaction, face recognition, online conference, face tracking, body recognition, gesture recognition etc. M6 comes with ePTZ function, which brings users a better experience in video call scenarios. Brand-new AI interaction logic will make the traditional TV be a smart screen. Various Applications More intelligent applications are supported including 5G 4K real-time playback, video conference system, smart teaching, office applications, dual screen digital signage, facial recognition payment systems, edge computing, shopping mall guides, leisure and entertainment, smart dining, airport information, intelligent robots, security systems, industrial control, outdoor advertising and multi-screen applications etc.
https://www.zidoo.tv/Products/M6/common/images/m6_overview/ov_02_en.pngLast edited by trebor; 13 August 2021, 08:14.
There are currently 2304 users online. 1 members and 2303 guests.
