KitKat 4.4 GoogleHome Launcher working on MK808
    I successfully got the KitKat's GoogleHome launcher running on the MK808, with GoogleNow integration, running in tablet mode and working perfectly. I got the non-bluetooth MK808, but I think with the MK808B it should accept bluetooth voice inputs (the option can be enabled in Google Now's settings).
    First you need to flash a 4.2.2 rom, since I couldn't get it working on any of my 4.1 Android devices.
    Then get these three apk files from the Nexus 5 or latest KitKat build:
    (Prebuilt)GmsCore.apk (Google Play services), GoogleHome.apk (launcher), Velvet.apk (Google Now).
    They can be downloaded here in a flashable package. However, I extracted mine from the Paranoid Android signed gapps package which is a more trustworthy source. Two of the required apk is founded in the /system/priv-app folder: paranoidandroid.co/roms/gapps
    Then I used a root file explorer and move all three apk files into the /system/app folder. Also fixing their file permissions to rw-r-r, or 644. Trying to install them directly won't work from my experience. Make sure you uninstall and delete the older version of Velvet/GoogleSearch/GoogleNow and GsmCore/GooglePlayservices first.
    After that you might see the blue Launcher icon in your app drawer, but it won't work yet until you reboot.
    If you want to swipe from the left to display Google now (see here), you need to log into your Google account and enable Google Now (tap and hold on the Google Launcher's homescreen and go to Settings).
    For voice recognition, you could also: tap and hold on the homescreen -> Settings -> Voice -> Offline speech recognition, download the English (US) package.
    Re: KitKat 4.4 GoogleHome Launcher working on MK808
    Good work I will test it.
    leolas.
    My devices:
    Gearbest.com)
      4.4 Launcher
      Thanks. I updated my Galaxy Nexus Running 4.3 and to my MK808. Looks much Nicer. The only issue it the Icon names do not display fully.
        any kitkat for rock chip?
        The user is currently not active, and in hiatus mode. please forgive me. will be back soon as i get my new rockchip device
