M9 vs M9 Pro
    M9 vs M9 Pro
    could anyone tell me how much difference with M9 and M9 Pro
    interm of
    - smoothness
    - screen quality
    - touching response
    - gaming performance
    because I have to choose one of these 2 devices
    and I heard that M9 Pro is slow and feel laggy
    if it not too much difference, I'll choose M9 pro
    is it's huge difference on performance, smoothness, I'll choose M9
    Thank you so much
    ,sorry for my English, I'm not native
    T^T
    no answer T__T
    pleasee
    I need some advice or recommendation
    thank you so much
      Bro
      I have an M9 max and overall i am pretty happy with it, plus its cheaper like 50 euros.
      I have read enough about the 2 and the better in PRO is that the screen resolution is higher and the image quality is a little prettier, but only a bit. Yet that higher resolution would affect gaming performance since the CPU and GPU are the same in both models. For overall use the PRO will be just a bit laggier than the max because of its higher resolution. But not so much, PRO also has a Bluetooth V4.0 so if you're into transferring files with BT, instead of WIFI, and reading books on the tablet, the PRO is better.
      I'm currently using the MAX with the Riley 2.1 ROM and an overclocked kernel and its working pretty well
      I think that info should be enough.
