H96 pro 2gb /16gb
H96 pro 2gb /16gb
I was installing the slimbox rom using SD card and got stuck in 90% around, I wait for 10hours check again and I disconnected, try to reboot and not luck the box is brick not video out. I tried to use the USB burn doesn't connect the box with the computer, I'm not sure which is the otg USB port are 4ports . Any idea also I use a new power adapter plus the USB cord pressing the reset button.
Tags: None
Originally posted by RiCkLaR_atvX View PostBest to just use CoreELEC software on an old box like yours. But if you want Android then try the ROM's from Superceleron, there is an old android 7.1.2 rom and a newer android 9.0 rom.
thanks
There are currently 2823 users online. 0 members and 2823 guests.
