Custom kernel for PiPo M9
Helo dnkn.
Can you try to include vsync fix in your kernel?
You can read about it there:
http://hwswbits.blogspot.hu/2013/10/...vsync-fix.html
http://www.freaktab.com/showthread.p...-rk3188-kernel!
https://github.com/phjanderson/Kerne...p/rk_fb.c#L388
I can test it on my tablet.
I can test it on my tablet.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Re: Custom kernel for PiPo M9
Our testing has revealed that the vsync fix kills video performance on these tablets.
Sent from my M6pro using Tapatalk 2Randy
this whole thread and project started out with so much power and suddenly it just died.
Is there still some development for a custom M9 kernel or has it stopped completely? Is DNKN active in other bulletin boards?
It's just sad to see so much promising development go to waste...
Regards
Vibsi
Regards
Vibsi), but don't appear to be much progress to date...
I've tested some new features, but they do not seem to be effective.. But hotplug CPU governor seems to save some juice without noticeable drop in performance. It switches off unused cores. So when you watch video there's only one or two cores online. Depending in the system load.
I've made plenty of tests, measuring memory performance to find the best and most power effective values. Looks like 528-576mhz Is enough for m9.
Rk3188 has single channel 32bit memory bus which ruins 3d performance in some (not any) games. Where memory bandwidth is vital (heavy textures processing).
I'm using my kernel everyday and tablet performs much better and without any noticeable battery drain, moreover, I got 10.5 hours of 1080p video payback, got ~9 on stock kernel. Now I'm trying to make a kernel to run native Linux. And also trying to build cm11 (compiled it, but had no time to test).
Отправлено с моего S5301 через Tapatalk
There are currently 2382 users online. 2 members and 2380 guests.
