The first one worked very well I wanted to test the other 2 which worked with bugs like remote control operation, with the 3 it is still rooted more medium than reflashed with USB burning tool 3.1.0.
the problem USB port which is more recognized yet worked before for flashed the 3, I think that its must be the custom 3 rom which block.
Just to know how to do a direct reset on the motherboard of the MXQ android box, make a trip to reset the card.
Thank you
Sorry I'm French I use google translation thank you
I put 4 motherboard photos can you tell me where I can do a reset on the motherboard thank you
