Zidoo M6: RK3566 development motherboard a bit of a Beast,
Not aimed the Home User but maybe of interest if you are into this type of thing
More for the Power User or Industrial, Digital signage and other AIot products.
It has a lot going on the Inside as you will read and see in the following Photos:
The Box:
What's in the Box: Power supply AU type remote and a Very good looking HDMI cable:
Front: Power Switch: Power LED Headphone Socket
Rear: the Usual HDMI, Ethernet, SPIDF USB Micro OTG, HDMI and Serial Port
Side one only: USB and Tf card slot
Remove the base:
Out with the PCB
Lots going On here: No 5g on the Unit I have:
And here just a little going on here:
From Zidoo Website:
M6 Mini PC Core Board
M6 is a multi-functional development board, or you can say it is Mini PC AI smart box.
It supports multiple application extension and greatly shortens the developing cycle
Fully Equipped Ports with Rich Scalability
Main ports: HDMI2.0, USB OTG, 2xUSB2.0 Host, Optical, GIGABIT LAN, RS232, TF Card, IR, Power key
Extended ports: LVDS, eDP, MIPI DSI, MIPI CSI, MIPI CIF camera, PCIe, I2C, UART, ADC, GPIO, I2S, VFD, Speaker,
microphone array and other ports. Various ports can be used to external device control and expansion
Quad-core 64-bit Cortex-A55 CPU
The CPU is a Quad-core 64-bit Cortex-A55, and the CPU clock speed up to 1.8GHz
GPU adopts dual-core architecture, ARM Mali-G52 2EE supports OpenGL ES 1.1/2.0/3.2,
OpenCL 2.0, Vulkan 1.1 and internal high-performance 2D acceleration hardware
Performance is greatly improved and 8K video decoding is supported
With 22nm advanced technology, lower power consumption
GPU VPU NPU Cooperative Accessing
Perfect cooperative accessing with dual-core architecture GPU, high-performance VPU and effective NPU
VPU can support 4K 60fps H.265/H.264/VP9 video decoding and 1080P 100fps H.265/H.264 video encoding
The build-in NPU supports INT8/INT16 hybrid operation and has strong compatibility
Network models based on a series of frameworks such as TensorFlow/MXNet/PyTorch/Caffe can be easily converted
Along with the popularization of UHD large-screen TVs, hardware upgrade is imminent
4K UHD mini PC M6 has a high-performance GPU capable of decoding 8K video maximum
HDR10/HDR HLG, HDR2SDR/SDR2HDR are supported
Images can be clear under backlight and harsh light condition
Specifications as follows
Model ZIDOO M6 Mini PC:
SOC RockChip RK3566
CPU Quad-core 64-bit Cortex-A55 processor, 22nm advanced technology, CPU clock speed up to 1.8GHz
GPU ARM G52 2EE
Support OpenGL ES 1.1/2.0/3.2,OpenCL 2.0,Vulkan 1.1
Embedded high-performance 2D acceleration hardware
NPU 0.8Tops@INT8, Integrated high-performance AI accelerator RKNN NPU
Support Caffe/TensorFlow/TFLite/ONNX/PyTorch/Keras/Darknet mainstream architecture model.
VPU Support 4K 60fps H.265/H.264/VP9 video decoding
Support1080P 100fps H.265/H.264video decoding
Support 8M ISP
RAM 2GB / 4GB(standard)/ 8GB LPDDR4 (optional), eMMC5.1
32 Bit width, support full link ECC
Internal Storage 16GB/32GB(standard) / / 64GB / 128GB eMMC (optional)
TF-Card Slot x1
Hardware Parameters
Ethernet Gigabit Ethernet is supported(RJ45, 100M/1000M bps)
WiFi Support WiFi6 2.4GHz/5GHz dual band WiFi,802.11 a/b/g/n/ac/ax protocol, downward support WiFi5 (WiFi6 is optional)
Support BT5.0
5G Broadband Support 5G and 4G LTE module full NetCom (network module is optional) PCIe×1
Display Port 1 × HDMI2.0, support 4K@60fps output
Audio Ports 1 × HDMI audio output
1 × Optical output
1 × 3.5mm headphone output (Analog L R output)
USB 1 × USB OTG 、2× USB2.0 HOST
RS232 Debug Port Support RS232 protocol debug port
TF Card Support 64GB-128GB
IR IN IR infrared remote control receiver
Power Supply DC 5V 2A
RS232 Port 1×RS232 port
Extension Ports "Display ports:1 ×LVDS(RGB888 RGB666), 1 ×MIPI CSI, 1 × MIPI DSI, support 1920*1080@60fps output (or dual channel 1 × MIPI DSI 2560*1440@60fps), 1×eDp(1.3 interface 4 wire 10.8Gbps up to2560*1600@60Hz)
Camera: 1×MIPI-CIF Camera
Microphone: Microphone array, MIC
Others: I2C, UART, ADC, GPIO, PCIe, I2S, VFD, Speaker, G-Sensor."
Built-in TCON-EBC, support RTC time circuit (cell battery could be built in)
Software Parameters
System Support Android 11.0 , (Ubuntu 18.04, Buildroot + QTStation OS custom system)
