I don’t even know if I should have laid it out? I don’t have the opportunity to check this firmware, since I don’t have such a TV box.
Test android 12 for X96 max plus 2gb/16gb
I don't have such a TV box. So everything you do you do at your own peril and risk. Think several times before flashing. The fact is that there is a multidtb here, which consists of 2 dtb for 2gb and I do not know which one works. Here is the firmware that I made. Perhaps, if it does not start, then you will have to change it to another dtb in the firmware. Such things.
Tags: None
There are currently 2152 users online. 0 members and 2152 guests.
