On multiple sites it says it is using the S905W chipset, but I don't know if that's the case with my android box. Also, which custom firware would be compatible with this box?
Help identifying Amlogic CPU chipset and compatible custom firmware (Tanix TX3 mini bought 2018)
Here are the specs from CPU-Z: https://imgur.com/a/6z0eM5J
On multiple sites it says it is using the S905W chipset, but I don't know if that's the case with my android box. Also, which custom firware would be compatible with this box?Last edited by andrewly3; 22 November 2021, 21:30.Tags: None
There are currently 3988 users online. 1 members and 3987 guests.
