More info..but in Russia: ( use translator )
blocklist
So, here is a neat way to run pi-hole on android ( or a linux distro )
found on Xda :
Requirements :
root / 2gb of free-space / atleast a device with 2gb of ram / static ip
( note : if you don't have root.. try Androlinux )
So, my android devices/clients are running Netguard*
*To manage what apps can be allowed to access internet
Under settings/advanced/enable Filter data/under VPN-Dns (use pi-hole Ipadress)
This forces all apps to use pi-hole
I installed pi-hole on my rk3566, and its working quite well..
while watching iptv it's using about 1.4 gb of ram ( total ram usage..used by device )
with 6 client connected to pi-hole server
just sharing some knowledge..
Cheers
